Nucleus Media Storage and Audio Devices
Nucleus Media Storage And Audio Devices
Storage Devices
Roon can watch multiple storage locations for files at the same time. That means you can simultaneously use any (or all) of the following storage locations:
Devices connected directly to Nucleus by USB
If your music is stored on an external USB drive, plug it into your Nucleus now. Nucleus supports USB drives pre-formatted as EXT2/3/4, VFAT/FAT32/FAT16/exFAT, NTFS, or HFS/HFS+. Note that HFS/HFS+ (also known as "Mac OS Journaled") is read-only, which means that the Nucleus will not be able to make changes or store new music on the USB drive.
A hard disk drive (HDD) or solid-state drive (SSD) connected inside the Nucleus via SATA
If you have a 2.5" hard drive you'd like to use as internal storage, we'd recommend following this installation guide
Network shares (such as a NAS)
For now, just make sure the NAS is turned on and plugged into your network. If you have a username/password for your share, take note of it now. We highly recommend connecting networked storage via ethernet always. Learn more about setting up your NAS over your network here.
Audio Devices
Roon can output audio to devices in the following ways:
If you plan to use a DAC, headphone amp, A/V receiver, integrated amplifier, or active speaker system connected directly to Nucleus via USB, connect them to one of the ports on the back panel of the Nucleus and make sure it's powered on.
Devices connected directly to Nucleus by HDMI
If you have an A/V receiver or another device with an HDMI audio input, you can connect the HDMI output on the back panel of the Nucleus to it. The HDMI output supports both stereo and multi-channel audio content.
Network audio devices
More and more audio devices of all kinds (active speakers, DACs, integrated amplifiers, and A/V receivers) have networking capabilities. If you have any Roon Ready, AirPlay, Sonos, or other supported streaming audio devices, you should check that they are connected to your network (via ethernet or WiFi as appropriate) and powered on. We recommend connecting networked audio devices via ethernet if possible.
If you're still having problems getting your storage locations or audio devices set uplet us know
    • Related Articles
    • Nucleus Migration Guide
      If you're setting up Nucleus, and your Roon Server had previously been running on Mac, Windows, or Linux, you'll need to migrate your Roon database. Your database includes your playlists, edits, play history, tags, settings, and more. This guide will ...
    • Storage
      Overview In Roon, Storage refers to the location(s) of your local library. Below, you will find a handful of popular storage locations along with their descriptions. Local Folders On first launch, Roon will find the default music folder on your ...
    • Nucleus Internal Storage
      Nucleus supports placing an HDD or SSD into its case, to create a fully contained solution. If you chose to use an SSD here, the system will stay fully silent. The drive needs to be formatted using the Nucleus web administration interface before it ...
    • Nucleus Manual
      Introduction What is Nucleus? At the heart of every Roon system is a Roon Server. This is the brain behind the entire Roon experience – it manages your music collection, streams to your audio devices, and stores the Roon database. Nucleus was ...
    • Nucleus Web Administration Interface
      Connecting to the Web Administration Interface You can use a web browser to perform operations like configuring settings, updating firmware, formatting internal storage, and resetting to factory settings. To use Roon to help you load up the Nucleus ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
