DSP Engine: Parametric Equalizer
MUSE - Precision Audio Control: Parametric Equalizer
Introduction
The Parametric Equalizer is part of the MUSE suite. For more information on accessing MUSE, see here.
Each MUSE configuration comes with a Parametric Equalizer by default. You can configure multiple equalizers if desired using the "Add Filter" button. You can also use the Parametric EQ from inside of the Procedural Equalizer if you only want to apply it to a subset of the channels.
When using the Parametric EQ, be sure to keep an eye on Headroom Management to avoid clipping.
Using the Parametric Equalizer
This is one of the most beautiful audio-related features in Roon. It's worth playing with once, even if you don't end up using it.
In Roon
In ARC
What to do with it?
Find an EQ curve for your favorite headphones
Lots of headphones can benefit from a little bit of EQ . The above screenshot is an EQ curve for Sennheiser HD650s that we found here
Turn up the bass and have some fun
Everyone does it once! Give yourself a little bit of extra bass. We won't tell.
Work out a killer house curve
 Have fun learning about digital filters
Our parametric EQ supports many of the most commonly discussed filter types. It's a great playground for learning about this stuff and experimenting with their effects on your favorite music.
    • Related Articles
    • MUSE - Precision Audio Control
      MUSE - Precision Audio Control (DSP) gives you tools that can potentially create loud or damaging sounds. Begin by experimenting at low volume levels until you are confident that your settings produce the desired effect. If you experience unwanted ...
    • MUSE - Precision Audio Control: Procedural Equalizer
      The Procedural Equalizer is part of Roon's MUSE Suite. For more information on accessing MUSE, see here. Procedural EQ is not included in MUSE for ARC The procedural equalizer is used for advanced audio control configurations like digital crossovers, ...
    • MUSE - Precision Audio Control: Headroom Management
      Introduction Headroom Management is part of the MUSE suite. For more information on accessing MUSE, see here. Digital signal processing can result in "clipping", or audio samples that exceed the allowed range. These samples are "clipped" to a maximum ...
    • MUSE - Precision Audio Control: Accessing the MUSE suite
      There are several ways to access the MUSE - Precision Audio Control suite. In Roon From your volume controls: By right-clicking or long-pressing the current zone icon: From Signal Path: Using a keyboard shortcut: Windows: Ctrl-/ Mac: Command-/ In ARC ...
    • MUSE - Precision Audio Control: Speaker Setup
      Speaker Setup is part of Roon's MUSE suite. For more information on accessing MUSE, see here. Speaker Setup is not included in MUSE for ARC. Speaker setup helps correct inconsistencies in speaker placement or sensitivity. For example, if the speakers ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
