MUSE - Precision Audio Control: Procedural Equalizer
The Procedural Equalizer is part of Roon's
MUSE Suite.
For more information on accessing MUSE,
see here.
Procedural EQ is not included in MUSE for ARC
The procedural equalizer is used for advanced audio control configurations like digital crossovers, custom crossfeeds, and manual room correction. It allows you to enable and configure a series of audio control steps in a preferred order, to perform matrix mixing, and to decide which steps apply to which channels.
There are seven signal processing operations available in Procedural EQ, they are: Parametric EQ, Generic
IIR filter, Mute channels, Volume, Delay, Mix, and Invert phase.
You can add as many as you like and arrange them in the order of your choice. Just remember that heavy digital signal processing can have an impact on CPU performance. If you experience performance issues after applying Procedural EQ try disabling some of the operations you've applied.
Please feel free to visit our
community and let us know if you have any questions or feedback about using MUSE in Roon.
Related Articles
MUSE - Precision Audio Control (DSP) gives you tools that can potentially create loud or damaging sounds. Begin by experimenting at low volume levels until you are confident that your settings produce the desired effect. If you experience unwanted ...
MUSE - Precision Audio Control: Parametric Equalizer
Introduction The Parametric Equalizer is part of the MUSE suite. For more information on accessing MUSE, see here. Each MUSE configuration comes with a Parametric Equalizer by default. You can configure multiple equalizers if desired using the "Add ...
MUSE - Precision Audio Control: Headroom Management
Introduction Headroom Management is part of the MUSE suite. For more information on accessing MUSE, see here. Digital signal processing can result in "clipping", or audio samples that exceed the allowed range. These samples are "clipped" to a maximum ...
MUSE - Precision Audio Control: Accessing the MUSE suite
There are several ways to access the MUSE - Precision Audio Control suite. In Roon From your volume controls: By right-clicking or long-pressing the current zone icon: From Signal Path: Using a keyboard shortcut: Windows: Ctrl-/ Mac: Command-/ In ARC ...
MUSE - Precision Audio Control: Speaker Setup
Speaker Setup is part of Roon's MUSE suite. For more information on accessing MUSE, see here. Speaker Setup is not included in MUSE for ARC. Speaker setup helps correct inconsistencies in speaker placement or sensitivity. For example, if the speakers ...
Visit the Roon Community!
Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
